Water cooling case suggestions
Juggalo23451
CASE LABS
MH10 -holds 360 rads
TH10 4 480 rads put 6 480 rad in if you want to
STH10 -480 rads
Cooler Master Cases
HAF932- 360 rad top
HAFX- 360 rad top
ATCS 840- 360 rad top rad on the HDD cages
COSMOS II- 360 rad top, or 480 top modification required. 240 rad bottom
CM690- 240 rad with modification
Storm Scout -360 rad with modification
Cosmos S- 360 rad top
SILVERSTONE
TJ07- 480 rad and 240 rad bottom
TJ11
LIAN LI
PC-P80-360 rad
Tyr PC-X2000F- 360 rad front
PC-A77(B)-240 rads modification
Lian-Li PC-V2120-360 rad on top and 280 in the front
NZXT
switch 810
Tempest EVO-240 rad thin
CORSAIR
800D-360 rad top, 240 rad bottom with modification
700D- 360 rad top, 240 bottom with modification
This is just awesome creativity... Well I really encourage you about this idea. This is the thing which no one an ordinary can have inside...
Well keep it up and best of luck for the next time...
what do u mean by this? You can have rads inside all the cases I suggested
I had the Cosmos S, Tempest case,TJ07, and I have the TH10 currently
