Water cooling solutions
TheChef
I am looking to get water cooling for my system, and am looking to buy a kit. I have come across a couple that are in my price range, definetly not extreme cooling, but I want to keep my componenets cold. How are the few that I mention here, any suggestions would be appreciated, but keep in mind that the Bigwater Cooling system is about as pricey as it can be. Here are two that I like.
Thermaltake BigWater
http://www.thermaltake.com/watercooling/cl-w0005bigwater/cl-w0005.htm
Best Price I've found is 102.
Kingwin AWC-1 Arctic Liquid Cooling System
http://www.kingwin.com/pdut_detail.asp?LineID=&CateID=53&ID=187
$84.00
I see that the BigWater Kit has to be installed using 4 holes around the CPU. Will my motherboard accept that or is there any other way to get around that?
Suggestions would be helpful.
I would go with the Tt bigwater, just an opinion, u mentioned that its $102, if you are willing to wait and save a little more $$, you can get a better WC kit than bigwater although i would not recommend a kit for performance reason and upgradability.Check on other brand like Swiftech, Corsair(swiftech rebranded) Asetek, Dangerden to name a few :)
joelkyr said:
...but if you would save a little more $$, you can get a better WC kit than bigwater although i would not recommend a kit for performance reason and upgradability.Check on other brand like Swiftech, Corsair(swiftech rebranded) Asetek, Dangerden to name a few :)
Not sure what you mean by "but if you would save a bit more money", but could you mention a couple of the better WC kits that are in that price range. Also, would I save money by getting individual parts instead of a kit?
EDIT: The water block fits, I just saw a video on installation.
