What is the best way to convert from WMA to MP3? NEED HELP A.S.A.P PLEASE HELP QUICK
Run a quick search and you will find tons of freewares as well as sharewares for that. Simply type "wav to mp3 converters freewares" in any search engine.
i think you might have trouble with that. If im not mistaken, wma files are protected, so without special software, i dont think you can. To convert others, most media players like windows media player will do some conversions, or like the other dude said, there is a crap-load of freeware out there if you search for it.
Like i said though. I could never find free software that would convert wma.
http://www.wmaconverter.com
This one is fairly popular i think:
http://www.soundtaxi.info/
I am using this one now. I think it has a free 15 day trial.
http://www.blazemp.com/convert_drm_protected_wma.htm
GOOGLE MAN
WMP 10 + 11 both have the into mp3 converter right there as long as the original format is compatible. If you have some odd format type used by only one or more programs you would then have to run an extended search for a conversion tool. But most audio and vdeo formats alike are pretty much standardized.
Your music will loose some quality if you convert wma to mp3 because your recompressing an already compressed audio file .
So, it is better to convert the original source to mp3
But by the way, why you want to convert wma to mp3 ?? because as I know most (if not all) mp3 players now can play wma
For my phone....
