WIFI connectivity problem.
panteramatt
I have a Toshiba L305-S5933 laptop and ever since Ive owned it, its had connectivity problems with the wifi at home. Im using windows vista and IE. Half the time, it connects right away. The other half, I have to manually connect it and sometimes I have to do it over and over and even restart the computer unplugged. Its not a signal or battery problem either. Can someone help?
Is it just at home or are you having the same issue at wifi hotspots? If its just at home then just delete the existing wireless connection details for you home and reset it all up.
Open the network and sharing center from control panel. On the left hand side you will see where it says "manage wireless connections", click on it. Then all you do is find your home connection and delete it. Then connect to it again but this time make sure you get the security key entered right if the router is secured. If after this you are still having issues then you should see if there is an updated driver for the wireless card.
