Will these parts go together fine?
Tyler1129876
Hello,
I am about to build my first computer and I would like to know if these internal parts go together. ;)
Case: NZXT Phantom 410 Mid Tower Case. (Red)
Power Supply: Thermaltake 850W Tough Power Gold
Motherboard: ASRock Z87 Killer
Processor: Intel Core i5 4670K 3.4GHz
CPU Cooler: CoolerMaster Hyper 212 EVO
Graphics card: ASUS GeForce GTX 770 2GB
HDD: Seagate Barracuda 3TB ST3000DM001
SSD: Corsair Force Series GS 128GB
RAM: G.Skill Ripjaws X F3-14900CL9Q-16GBZL 16GB (4x4GB) DDR3
Operating System: Windows 8.1 Pro 64Bit
Optical Drive: ASUS DRW-24D3ST
It would also be great if you could tell me all the cables I need for each part (If Any).
Thanks,
- Tyler
Get the 2x8gb kit instead.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231528
To run the actual 1866mhz, you will have to go into the bios and manually enter the voltage and timings for the ram as the board only supports up to 1600mhz without overclocking.
850 watt power supply is overkill, a nice 650 watt unit will suffice.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153186
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139012
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207031
