VvCompHelpvV
I built a comp online…piece by piece. I need your input as to tell me if this will all work together. I’m almost certain it will. I just need someone to look it over and tell me if I missed something that’s not compatible.
Also…will it work nicely together? I am going for a nice Autodesk Maya Workstation Graphics card comp… NOT GAMING.
**Reason why the Graphics card is a Quadro (plus I wanted the 3700)
Anyway…review it..tell me if the parts are:
1. Compatible
2. Will work smoothly. This is the first computer I’ve ever built.
Specs:
CASE
Cooler Master HAF 922
http://www.tigerdirect.com/applicat...?EdpNo=4631382&csid=ITD&body=MAIN#detailspecs
CPU
Intel Core i7 930
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5719283&CatId=4074
MOBO
Asus P6T
http://www.tigerdirect.com/applicat...1&csid=ITD&recordsPerPage=5&body=#ReviewStart
GRAPHICS CARD
Quadro FX 3700
http://www.buy.com/prod/pny-quadro-...-0-x16-sli-supported/q/loc/101/206917838.html
RAM
Corsiar Tri Channel 2GBx3=6GB RAM Total
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5265586&CatId=4327
EASY WATER COOLING
Corsair Hydro H50
HDD
Seagate Pipeline HD
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148539
PSU
OCZ OCZZ650 Z Series Power Supply - 650-Watt
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5344847&CatId=106
DVD BURNER
Lite-On DH-24AAS
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5376694&Sku=L12-1362 OEM
EXTRA FAN
Cooler Master:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5034940&CatId=5404
MEM CARD READER
PowerUp GEN 9010
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2415753&CatId=942
So let me know what you think….I need help here…I don’t want to order the parts (won’t be for a while…I need to save up) and they don’t work together…or it won’t run smoothly.
Thanks so much!
1. Compatible
Specs:
CASE
CPU
Intel Core i7 930
MOBO
Asus P6T
GRAPHICS CARD
Quadro FX 3700
RAM
EASY WATER COOLING
Corsair Hydro H50
HDD
Seagate Pipeline HD
PSU
DVD BURNER
Lite-On DH-24AAS
EXTRA FAN
Cooler Master:
MEM CARD READER
PowerUp GEN 9010
Thanks so much!
