Wireless network @ work problem
ghost
Hello all, I have come across an annoying problem with our wireless network at work and hoping someone here may be kind enough to enlighten me. Right here goes...
Down stairs there are 3 access points (D-link Wirless G hubs) and are connected to the network. They are all called the same thing in the SID and the security is WEP128. But heres the problem.
The building is 6 rooms long and there is a wireless hub in every second room. The idea is when you walk though the rooms with a laptop it connect the the wireless hub with the strongest signal. But it only works sometimes...
This is causing a bit of a headache for my colleagues. Sometimes it works well, but not all the time. For example it will connect to a wireless hub and will not move on to the next one even if it loses signal strength.
Is there some sort of wireless roaming 3rd party software I can use, or maybe the hubs or laptops aren't configured properly?
Ideas and suggestions will be fantastic :)
Thanks for your help and time in advance.
Very tricky, as need something thats going to be able to piggy-back from one connection to another. Without naming them differently and then manually connecting to each one when moving I cant think of any other way.
