dishman
My scenario:
I have a wireless LAN with 3mbps cable internet connection.
My friend has a wireless LAN with no internet connection.
I want to share my internet connection with my friend whose house is 4 miles away direct line of sight.
I built 2 biquad antennas (28db og gain) then attached them to a pair of 30 inch dishes and plan to install them on our roofs.
What extra equipment do I need to connect our two wireless LANs.
My question is:
Should I hook up a wireless access point to one of the ports on my wireless router and then hook up the dishes pigtail to the access point and then at my friend’s house should I hook up the dishes pigtail to a wireless bridge and then run the bridges port to the wan port on his wireless router? will this format work?
This is an image model of what I think may work, but I would love some conformation before I buy all of the equipment.
My question is:
