H Hamster New Member Jun 20, 2010 #1 Anyone know where I can find the parts to this CPU cooler? I need the clamps and fan controller. http://www.newegg.com/Product/Product.aspx?Item=N82E16835118223
diduknowthat formerly liuliuboy Jun 20, 2010 #2 Well the fan controller you can buy off newegg, it's just the standard zalman fan controller. Not too sure about the clamp though.
Shane Super Moderator Staff member Jun 20, 2010 #3 Id contact Zalman Directly and see if they would sell you a "Replacement" set of clamps....probably a long shot but you never know.
FuryRosewood Active Member Jun 21, 2010 #4 yea id contact the manufacturer, and you are likely to be able to get the parts, their a good company, so i wouldnt see why they wouldnt give/sell you them
C CravinR1 New Member Jun 21, 2010 #5 Is it for am2/am3? I might have an extra amd mounting bracket (using my 9500 on lga 775)
mep916 Administrator Staff member Jun 22, 2010 #6 Call zalman. They'll hook you up. At no cost, they shipped me a set of replacement 9700 AMD hardware.
W WiseCow New Member Jun 13, 2011 #7 Replacement Bracket for Zalman 9700 you need the Zalman ZM-CS5A Socket 1155/1156/775 Clip Kit Order it at Amazon for $10 it is aso good for these coolers: CNPS10X / 9900 / 9700 / 9500 Series or ZM-WB5 Plus
