My framerate have reach less than 60 FPS on Final Fantasy 14: Realm Reborn, iRacing.com, and Skyrim. So I decided it is time to built whole machine. Keep in mind, I am only using one videocard, one hard drive, one DVD and using on board sounds, so I don't need ATX motherboard and mid tower case unless if it is cheaper for gaming.
My current use.
Mainboard: Gigabyte Z77X-UD5H
Processor: Intel Core i5 2500K
Physical Memory: 8 GB (2X4GB DDR3-1600 SDRAM)
VideoCard: GTX 560Ti 448 Cores
Power Supply: Corsair TX 650W
Hard Disk: Seagate ST500DM002 (500GB) (getting full.)
DVD-Rom Drive: Hewlett Packard DVD Writer 1260t
Case: Antec 900 Hundred.
Processor: Intel Core i7-4790K Haswell Quad-Core 4.0GHz LGA 1150 $339.99
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&IsNodeId=1&N=100007671 600436886 600005731
I am looking forward to built one of these motherboard.
1.ASUS MAXIMUS VII GENE $214.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16813132136
2.MSI Z97M Gaming $159.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16813130773
3.ASRock Fatal1ty Z97M Killer $134.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16813157566
4.GIGABYTE GA-Z97MX-Gaming 5 $127.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16813128716
Physical Memory: G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2400 (PC3 19200)$76.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16820231666
Hard Drive: Western Digital Blue WD10EZEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" $54.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16822236339
DVD Drive:SUS 24X DVD Burner - Bulk 24X DVD+R 8X DVD+RW 8X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 24X CD-RW 48X CD-ROM Black SATA Model DRW-24B1ST/BLK/B/AS $19.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
VideoCard: MSI GTX 970 4GD5T OC GeForce GTX 970 4GB 256-Bit GDDR5 PCI Express 3.0 x16 HDCP $339.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16814127833
Power Supply: Rosewill TACHYON -650 650W Continuous @ 50°C, Intel Haswell Ready, 80 PLUS PLATINUM, ATX12V v2.31 & EPS12V v2.92, SLI/CrossFire Ready, Modular Active PFC $118.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16817182272
Case:Corsair Obsidian Series 350D CC-9011029-WW Black Aluminum / Steel MicroATX Case with Window $109.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16811139021
CPU fan: ZALMAN CNPS9500 AT 2 Ball CPU Cooling Fan/Heatsink $37.99 (hopefully it will fits) http://www.newegg.com/Product/Product.aspx?Item=N82E16835118003
Total cost will be $1319.91 to $1226.91. If I use my case, power supply and DVD drive over, it will be $1046.93 to $959.93. So what you think of my built?
My current use.
