I was about to say, dat cable management skills.... is non existent. XD
I still can't see it. Try a different hosting sitetry it now and let me know
And just for the record, cable management is not my strong suit
Try ctrl+f5 and clear your cache.I still can't see it. Try a different hosting site
Like the idea also Shane of the wheels. Have my tower on the table. Was at Harbor Freight
and seen the wheels. Didn't do it. would be blowing out 3 or 4 times a year on the floor.
Will keep on the table for now.
Installed my monitor mount today. Freed up so much space.
I had some when I had a blue color scheme but since I swapped to white I can't use them anymore but will buy new ones, don't worryNow, you just need to spend a butt load of money on braided cables.
Before or after the 3 way GTX 1080 SLI setup?will buy new ones, don't worry
Ok, I don't have THAT kind of money lmao.Before or after the 3 way GTX 1080 SLI setup?
You can't be far off though. How about two 1080s?Ok, I don't have THAT kind of money lmao.
