MicRaDoT932
when i go into dxdiag on vista it says my video card has 1016mb when its only 256mb. does any one kno y it does that?
mabe you should down grade to Xp Jk but seriously mabe theres a bit of overclocking goin on or vista has a bug displaying it at 1gb once i rember my comp had 1g of ramm but displayed as 99Mb
^^ Exactly Your vid card uses part of your memory along with the onboard memory on the vid card.
Lol I suprise myself sometimes ahhaha... K so if it's partially the cache file, where is the cache file located?
And also it's my understanding you can increase the size of a cache file, would that be possible to do and if so would it be wise to do so if your a gamer?
**EDIT** You already answered my question sorry I didn't read carefully..
you asked this question for Vista OS but you have mentioned that the OS is Windows XP in your system configuration field.
Confused?
Click me to resolve
why vista is so great once you get past the get used to it part...
