I was wondering if a duo 120mm radiator would fit a Armor+ LCS VH600LBWS?
http://www.thermaltakeusa.com/Product.aspx?S=1225&ID=1480#Tab0
I decided I'd go for this case and use water-cooling. Theres a barebone for one of these with a water-cooling system built in already, but I'd rather make my own. So, would a duo 120mm radiator fit? I can't use it in the back, for the exhaust, since there's only room for a single 120mm. The front and top can only occupy a single 120mm too, the side a 140mm, but the bottom can hold two 120mm. The problem is, not sure if I can install the grill on the bottom... plus, I'm worried about the heat. So, would it work, or is there a better case? I'd like one with a window.
Also, I was wondering, how would I install a resevoir into one of those 5.25" bays? With screws?
