pcmagic
Hi Folks
____
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml2/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en">
_____
When I added this to my template for my Dropdown Menu, It's changed the size of the cotent area..(LINKS BELOW)
** With Doctype and Dropdown Menu
** Without Doctype and With Dropdown Menu
REMOVED
_
it's not ignored the CSS but it's changed ... well you can see what it's changed.
Also I seem to have a structure problem, view the template on different
resolutions, Best viewed at 800x600...It's leaving gabs in between the tables the bigger the resolution gets....How do i fix that?
Any Tips..
Thanks, Much Appreciated
____
_____
REMOVED
_
Any Tips..
