Drivers Issue?
Candy
I have a GA-P35-DS3 R and lately i have been having a problem where when i do very low system intensive tasks, such as open certain programs, the music in the background will "lag" or "skip" and the mouse will also "lag". Also when i open my computer it does the same thing.
Now the reason i believe it is a mobo driver issue:
It was running fine until the other day when i realised i needed Adobe Reader and i remembered it was on the CD containing my mobo drivers. So i put in the CD and it then proceeds to tell me that all my drivers have been installed, which i already new, and restarts the computer like when you install them for the first time.
I have had this issue before and it got fixed when i installed vista ultimate and i used Windows Update to install all my drivers.
I have tried going update but it says i have the lastest drivers, also tried Gigabyte's website to reinstall but they dont have the lastest drivers, tried getting the latest chipset drivers off the Intel website but apparently they are no longer available.
Driver version is 9.0.0.1008
If anyone could help that would be awesome :)
Specs as in sig.
Can you restore your system to a point previous to the driver/Adobe install?
Yes, sorry i can, should of checked that first. It actually has made restore points showing that all the drivers were installed at that time so i will go back to before that.
Try that out and see if your problems continue.
