Format vista(labtop) without cd?
grill10
Is that possible? And if so, how?
I have a recovery cd for xp, and my other question is, if its possible to install xp on my labtop with vista sytem, using the recovery cd?
Thanks!!
Yes, i have a recovery cd(vista) for my labtop(vista), but how can i format and reinstall vista? is that possible?
yes i know that, but how? When i insert the cd, i get some options, but cant see where i can format, can someone plz write step by step, how to format the computer and the reinstall vista?
thanks
thanks
Laptop:)
What specific options do you have when the Recovery DVD loads up? I've never had to work with a Vista Recovery DVD before (so I'm not familiar with the exact wording/layout of different manufactures' options), but if it's anything like a normal version, you should see the options to (do a New) Install or Repair your existing one. You could try clicking on Repair, then doing a System Restore, but it sounds like you want to do a completely new Install. In that case, click Install and follow the on-screen instructions - formatting will be a part of that process.
Thanks for the answers!
The problem is that ive downloaded a recovery cd see this link:
http://thepiratebay.org/tor/4020989/Windows_Vista_Recovery_CD
But it doesnt seem to work, when i try to install vista, do you know why? I think i get en error message that some install file is missing...
thanks
That's a link to a torrent. Discussion of torrent downloads violate the forum rules, so we can't help you with that.
http://www.computerforum.com/109167-rules-reminder.html
http://www.computerforum.com/52038-forum-rules.html
