Hi Punk, how are you
Today I followed the steps of running avenger and DSS. Here are the results
Avenger-
Logfile of The Avenger Version 2.0, (c) by Swandog46
http://swandog46.geekstogo.com
Platform: Windows XP
Script file opened successfully.
Script file read successfully.
Backups directory opened successfully at C:\Avenger
Beginning to process script file:
Rootkit scan active.
No rootkits found!
File "C:\WINDOWS\system32\sex3.ico.tmp" deleted successfully.
File "C:\WINDOWS\system32\sex2.ico.tmp" deleted successfully.
File "C:\WINDOWS\system32\sex1.ico.tmp" deleted successfully.
Error: file "C:\WINDOWS\system32\perfc000.dat" not found!
Deletion of file "C:\WINDOWS\system32\perfc000.dat" failed!
Status: 0xc0000034 (STATUS_OBJECT_NAME_NOT_FOUND)
--> the object does not exist
Completed script processing.
Finished! Terminate.
Main-
Deckard's System Scanner v20071014.68
Run by mand on 2008-07-05 16:38:02
Computer is in Normal Mode.
-- System Restore --------------------------------------------------------------
Successfully created a Deckard's System Scanner Restore Point.
-- Last 5 Restore Point(s) --
18: 2008-07-05 11:08:09 UTC - RP321 - Deckard's System Scanner Restore Point
17: 2008-07-03 09:33:16 UTC - RP320 - System Checkpoint
16: 2008-07-02 08:44:34 UTC - RP319 - System Checkpoint
15: 2008-06-30 17:12:50 UTC - RP318 - System Checkpoint
14: 2008-06-29 15:30:05 UTC - RP317 - System Checkpoint
-- First Restore Point --
1: 2008-04-17 15:18:01 UTC - RP304 - System Checkpoint
Backed up registry hives.
Performed disk cleanup.
Percentage of Memory in Use: 80% (more than 75%).
Total Physical Memory: 479 MiB (512 MiB recommended).
-- HijackThis (run as mand.exe) -----------------------------------------------
Scan saved at 4:39:00 PM, on 7/5/2008
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Common Files\LightScribe\LSSrvc.exe
C:\Program Files\Eset\nod32krn.exe
D:\Program Files\Microsoft Private Folder 1.0\PrfldSvc.exe
C:\Program Files\Canon\CAL\CALMAIN.exe
C:\WINDOWS\RTHDCPL.EXE
C:\WINDOWS\system32\rundll32.exe
C:\Program Files\Java\jre1.5.0_09\bin\jusched.exe
D:\PROGRA~1\Nokia\NOKIAP~1\LAUNCH~1.EXE
D:\Program Files\Microsoft Office\Office\1033\OLFSNT40.EXE
C:\PROGRA~1\COMMON~1\PCSuite\Services\SERVIC~1.EXE
C:\WINDOWS\system32\wuauclt.exe
C:\Documents and Settings\mand\Desktop\dss.exe
C:\PROGRA~1\TRENDM~1\HIJACK~1\mand.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = about:blank
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL =
http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL =
http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page =
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - D:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: Megaupload Toolbar - {4E7BD74F-2B8D-469E-CCB0-B130EEDBE97C} - C:\PROGRA~1\MEGAUP~1\MEGAUP~1.DLL
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.5.0_09\bin\ssv.dll
O2 - BHO: Console Flash v.4.1 - {BCC8A4AB-C055-461E-B4B5-1B0EA8647897} - C:\WINDOWS\system32\confl.dll
O3 - Toolbar: Megaupload Toolbar - {4E7BD74F-2B8D-469E-CCB0-B130EEDBE97C} - C:\PROGRA~1\MEGAUP~1\MEGAUP~1.DLL
O4 - HKLM\..\Run: [IgfxTray] C:\WINDOWS\System32\igfxtray.exe
O4 - HKLM\..\Run: [HotKeysCmds] C:\WINDOWS\System32\hkcmd.exe
O4 - HKLM\..\Run: [High Definition Audio Property Page Shortcut] HDAShCut.exe
O4 - HKLM\..\Run: [RTHDCPL] RTHDCPL.EXE
O4 - HKLM\..\Run: [BluetoothAuthenticationAgent] rundll32.exe bthprops.cpl,,BluetoothAuthenticationAgent
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre1.5.0_09\bin\jusched.exe"
O4 - HKLM\..\Run: [PCSuiteTrayApplication] D:\PROGRA~1\Nokia\NOKIAP~1\LAUNCH~1.EXE -onlytray
O4 - HKLM\..\Run: [nod32kui] "C:\Program Files\Eset\nod32kui.exe" /WAITSERVICE
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\qttask.exe" -atboottime
O4 - HKLM\..\Run: [C:\WINDOWS\system32\kdvnf.exe] C:\WINDOWS\system32\kdvnf.exe
O4 - Startup: REALHOUND IP Tune and Lube.LNK = C:\Program Files\REALHOUND IP Client\realhoundiptuneandlube.exe
O4 - Global Startup: Symantec Fax Starter Edition Port.lnk = D:\Program Files\Microsoft Office\Office\1033\OLFSNT40.EXE
O4 - Global Startup: InterVideo WinCinema Manager.lnk = D:\Program Files\InterVideo\Common\Bin\WinCinemaMgr.exe
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_09\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_09\bin\ssv.dll
O12 - Plugin for .MOV: C:\Program Files\Internet Explorer\PLUGINS\npqtplugin.dll
O12 - Plugin for .mp3: C:\Program Files\Internet Explorer\PLUGINS\npqtplugin4.dll
O12 - Plugin for .mpg: C:\Program Files\Internet Explorer\PLUGINS\npqtplugin3.dll
O12 - Plugin for .spop: C:\Program Files\Internet Explorer\Plugins\NPDocBox.dll
O17 - HKLM\System\CCS\Services\Tcpip\..\{E7F78793-C4E9-43AC-B077-EC4B720BB791}: NameServer = 218.248.240.23,218.248.240.135
O23 - Service: Adobe LM Service - Adobe Systems - C:\Program Files\Common Files\Adobe Systems Shared\Service\Adobelmsvc.exe
O23 - Service: ASP.NET State Service (aspnet_state) - Unknown owner - C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_state.exe (file missing)
O23 - Service: Canon Camera Access Library 8 (CCALib8) - Canon Inc. - C:\Program Files\Canon\CAL\CALMAIN.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\1150\Intel 32\IDriverT.exe
O23 - Service: iPod Service - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: LightScribeService Direct Disc Labeling Service (LightScribeService) - Hewlett-Packard Company - C:\Program Files\Common Files\LightScribe\LSSrvc.exe
O23 - Service: NOD32 Kernel Service (NOD32krn) - Eset - C:\Program Files\Eset\nod32krn.exe
O23 - Service: Private Folder Service (prfldsvc) - Unknown owner - D:\Program Files\Microsoft Private Folder 1.0\PrfldSvc.exe
End of file - 5218 bytes
-- File Associations -----------------------------------------------------------
All associations okay.
-- Drivers: 0-Boot, 1-System, 2-Auto, 3-Demand, 4-Disabled ---------------------
R2 windrvNT - c:\windows\system32\windrvnt.sys
R3 SMBios (Intel (R) System Management BIOS Service) - c:\windows\system32\drivers\smbios.sys <Not Verified; Intel Corporation; Intel (R) System Management BIOS Driver>
-- Services: 0-Boot, 1-System, 2-Auto, 3-Demand, 4-Disabled --------------------
R2 CCALib8 (Canon Camera Access Library 8) - c:\program files\canon\cal\calmain.exe <Not Verified; Canon Inc.; >
R2 prfldsvc (Private Folder Service) - d:\program files\microsoft private folder 1.0\prfldsvc.exe
S3 aspnet_state (ASP.NET State Service) - c:\windows\microsoft.net\framework\v2.0.50727\aspnet_state.exe (file missing)
-- Device Manager: Disabled ----------------------------------------------------
No disabled devices found.
-- Scheduled Tasks -------------------------------------------------------------
2008-02-10 16:24:18 338 --a------ C:\WINDOWS\Tasks\Uniblue SpyEraser.job
-- Files created between 2008-06-05 and 2008-07-05 -----------------------------
2008-07-03 22:48:01 68096 --a------ C:\WINDOWS\zip.exe
2008-07-03 22:48:01 161792 --a------ C:\WINDOWS\swreg.exe <Not Verified; SteelWerX; SteelWerX Registry Editor>
2008-07-03 22:48:00 49152 --a------ C:\WINDOWS\VFind.exe
2008-07-03 22:48:00 212480 --a------ C:\WINDOWS\swxcacls.exe <Not Verified; SteelWerX; SteelWerX Extended Configurator ACLists>
2008-07-03 22:48:00 136704 --a------ C:\WINDOWS\swsc.exe <Not Verified; SteelWerX; SteelWerX Service Controller>
2008-07-03 22:48:00 80412 --a------ C:\WINDOWS\grep.exe
2008-07-03 22:48:00 89504 --a------ C:\WINDOWS\fdsv.exe <Not Verified; Smallfrogs Studio; >
2008-07-03 22:36:42 0 d-------- C:\WINDOWS\ERUNT
2008-07-03 22:26:15 0 d-------- C:\Documents and Settings\neel\Application Data\Datalayer
2008-07-03 22:26:13 0 d-------- C:\Documents and Settings\neel\Phone Browser
2008-07-03 20:46:14 0 d-------- C:\Documents and Settings\neel\Application Data\Apple Computer
2008-07-03 19:55:39 0 d-------- C:\Program Files\Trend Micro
2008-07-03 16:06:36 1152 --a------ C:\WINDOWS\system32\windrv.sys
2008-07-03 16:05:28 0 d-------- C:\Program Files\Common Files\Download Manager
2008-06-19 10:46:17 0 d-------- C:\Documents and Settings\All Users\Application Data\InterVideo
2008-06-19 10:46:02 9856 -----n--- C:\WINDOWS\system32\drivers\pfc.sys <Not Verified; Padus, Inc.; Padus(R) ASPI Shell>
2008-06-19 10:45:13 204800 --a------ C:\WINDOWS\system32\IVIresizeW7.dll
2008-06-19 10:45:13 188416 --a------ C:\WINDOWS\system32\IVIresizePX.dll
2008-06-19 10:45:13 192512 --a------ C:\WINDOWS\system32\IVIresizeP6.dll
2008-06-19 10:45:13 192512 --a------ C:\WINDOWS\system32\IVIresizeM6.dll
2008-06-19 10:45:13 200704 --a------ C:\WINDOWS\system32\IVIresizeA6.dll
2008-06-19 10:45:13 20480 --a------ C:\WINDOWS\system32\IVIresize.dll
2008-06-07 10:35:55 0 dr-h----- C:\Documents and Settings\mand\Recent
-- Find3M Report ---------------------------------------------------------------
2008-07-05 16:35:06 12 --a------ C:\WINDOWS\bthservsdp.dat
-- Registry Dump ---------------------------------------------------------------
*Note* empty entries & legit default entries are not shown
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{BCC8A4AB-C055-461E-B4B5-1B0EA8647897}]
06/03/2007 06:20 PM 208384 --a------ C:\WINDOWS\system32\confl.dll
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"IgfxTray"="C:\WINDOWS\System32\igfxtray.exe" [02/08/2005 11:06 PM]
"HotKeysCmds"="C:\WINDOWS\System32\hkcmd.exe" [02/08/2005 11:02 PM]
"High Definition Audio Property Page Shortcut"="HDAShCut.exe" [01/07/2005 05:07 PM C:\WINDOWS\system32\HdAShCut.exe]
"RTHDCPL"="RTHDCPL.EXE" [04/13/2005 11:51 AM C:\WINDOWS\RTHDCPL.EXE]
"BluetoothAuthenticationAgent"="bthprops.cpl" [08/04/2004 12:56 AM C:\WINDOWS\system32\bthprops.cpl]
"SunJavaUpdateSched"="C:\Program Files\Java\jre1.5.0_09\bin\jusched.exe" [10/12/2006 03:10 AM]
"PCSuiteTrayApplication"="D:\PROGRA~1\Nokia\NOKIAP~1\LAUNCH~1.exe" [12/13/2005 08:49 AM]
"nod32kui"="C:\Program Files\Eset\nod32kui.exe" [06/11/2007 03:10 PM]
"QuickTime Task"="C:\Program Files\QuickTime\qttask.exe" [04/27/2007 09:41 AM]
"C:\WINDOWS\system32\kdvnf.exe"="C:\WINDOWS\system32\kdvnf.exe" []
C:\Documents and Settings\mand\Start Menu\Programs\Startup\
REALHOUND IP Tune and Lube.LNK - C:\Program Files\REALHOUND IP Client\realhoundiptuneandlube.exe [10/9/2006 11:11:04 AM]
C:\Documents and Settings\All Users\Start Menu\Programs\Startup\
Symantec Fax Starter Edition Port.lnk - D:\Program Files\Microsoft Office\Office\1033\OLFSNT40.EXE [12/23/1998 2:21:54 PM]
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\policies\system]
"DisableRegistryTools"=0 (0x0)
"HideLegacyLogonScripts"=0 (0x0)
"HideLogoffScripts"=0 (0x0)
"RunLogonScriptSync"=1 (0x1)
"RunStartupScriptSync"=0 (0x0)
"HideStartupScripts"=0 (0x0)
[HKEY_CURRENT_USER\software\microsoft\windows\currentversion\policies\system]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\vds]
@="Service"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{533C5B84-EC70-11D2-9505-00C04F79DEAF}]
@="Volume shadow copy"
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Adobe Reader Speed Launch.lnk]
path=C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Adobe Reader Speed Launch.lnk
backup=C:\WINDOWS\pss\Adobe Reader Speed Launch.lnkCommon Startup
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Microsoft Office.lnk]
path=C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Microsoft Office.lnk
backup=C:\WINDOWS\pss\Microsoft Office.lnkCommon Startup
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder\C:^Documents and Settings^mand^Start Menu^Programs^Startup^Adobe Gamma.lnk]
path=C:\Documents and Settings\mand\Start Menu\Programs\Startup\Adobe Gamma.lnk
backup=C:\WINDOWS\pss\Adobe Gamma.lnkStartup
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder\C:^Documents and Settings^mand^Start Menu^Programs^Startup^REALHOUND IP Tune and Lube.LNK]
path=C:\Documents and Settings\mand\Start Menu\Programs\Startup\REALHOUND IP Tune and Lube.LNK
backup=C:\WINDOWS\pss\REALHOUND IP Tune and Lube.LNKStartup
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\iTunesHelper]
"D:\Program Files\iTunes\iTunesHelper.exe"
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\NeroFilterCheck]
C:\WINDOWS\system32\NeroCheck.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\QuickTime Task]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Yahoo! Pager]
"D:\Program Files\Yahoo!\Messenger\YahooMessenger.exe" -quiet
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\svchost]
bthsvcs BthServ
-- End of Deckard's System Scanner: finished at 2008-07-05 16:39:30 ------------
Extra-
Extra logfile - please post this as an attachment with your post.
-- System Information ----------------------------------------------------------
Microsoft Windows XP Professional (build 2600) SP 2.0
Architecture: X86; Language: English
CPU 0: Intel(R) Pentium(R) 4 CPU 3.06GHz
CPU 1: Intel(R) Pentium(R) 4 CPU 3.06GHz
Percentage of Memory in Use: 79%
Physical Memory (total/avail): 478.73 MiB / 98.27 MiB
Pagefile Memory (total/avail): 1426.36 MiB / 1109.7 MiB
Virtual Memory (total/avail): 2047.88 MiB / 1912.75 MiB
A: is Removable (No Media)
C: is Fixed (FAT32) - 9.76 GiB total, 3.89 GiB free.
D: is Fixed (FAT32) - 9.76 GiB total, 1.12 GiB free.
E: is Fixed (FAT32) - 9.75 GiB total, 1.59 GiB free.
F: is Fixed (FAT32) - 7.94 GiB total, 1.22 GiB free.
G: is CDROM (No Media)
\\.\PHYSICALDRIVE0 - ST340014A - 37.27 GiB - 4 partitions
\PARTITION0 (bootable) - Unknown - 9.77 GiB - C:
\PARTITION1 - Extended w/Extended Int 13 - 27.49 GiB - D: - E: - F:
-- Security Center -------------------------------------------------------------
AUOptions is disabled.
Windows Internal Firewall is enabled.
UpdatesDisableNotify is set.
AV: ESET NOD32 antivirus system 2.70 v2.70 (ESET, spol. s r.o.)
[HKLM\System\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile\AuthorizedApplications\List]
"%windir%\\system32\\sessmgr.exe"="%windir%\\system32\\sessmgr.exe:*:enabled
xpsp2res.dll,-22019"
[HKLM\System\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\AuthorizedApplications\List]
"C:\\Program Files\\Messenger\\msmsgs.exe"="C:\\Program Files\\Messenger\\msmsgs.exe:*:Enabled:Windows Messenger"
"D:\\Program Files\\Yahoo!\\Messenger\\YahooMessenger.exe"="D:\\Program Files\\Yahoo!\\Messenger\\YahooMessenger.exe:*:Enabled:Yahoo! Messenger"
"D:\\Program Files\\Yahoo!\\Messenger\\YServer.exe"="D:\\Program Files\\Yahoo!\\Messenger\\YServer.exe:*:Enabled:Yahoo! FT Server"
"C:\\Program Files\\Nokia\\Nokia Software Updater\\nsu_ui_client.exe"="C:\\Program Files\\Nokia\\Nokia Software Updater\\nsu_ui_client.exe:*:Enabled:Nokia Software Updater"
"C:\\Program Files\\Common Files\\Nokia\\Service Layer\\nsl_host_process.exe"="C:\\Program Files\\Common Files\\Nokia\\Service Layer\\nsl_host_process.exe:*:Enabled:Nokia Service Layer Host Process "
"C:\\WINDOWS\\PCHEALTH\\HELPCTR\\Binaries\\HelpCtr.exe"="C:\\WINDOWS\\PCHEALTH\\HELPCTR\\Binaries\\HelpCtr.exe:*:Enabled:Remote Assistance - Windows Messenger and Voice"
"D:\\Program Files\\iTunes\\iTunes.exe"="D:\\Program Files\\iTunes\\iTunes.exe:*:Enabled:iTunes"
"C:\\Program Files\\uTorrent\\uTorrent.exe"="C:\\Program Files\\uTorrent\\uTorrent.exe:*:Enabled:µTorrent"
"C:\\WINDOWS\\system32\\svchost.exe"="C:\\WINDOWS\\system32\\svchost.exe:*:Enabled:svchost"
"D:\\Program Files\\Skype\\Phone\\Skype.exe"="D:\\Program Files\\Skype\\Phone\\Skype.exe:*:Enabled:Skype"
-- Environment Variables -------------------------------------------------------
ALLUSERSPROFILE=C:\Documents and Settings\All Users
APPDATA=C:\Documents and Settings\mand\Application Data
CLASSPATH=.;C:\Program Files\Java\jre1.5.0_09\lib\ext\QTJava.zip
CLIENTNAME=Console
CommonProgramFiles=C:\Program Files\Common Files
COMPUTERNAME=COMPUTER
ComSpec=C:\WINDOWS\system32\cmd.exe
FP_NO_HOST_CHECK=NO
HOMEDRIVE=C:
HOMEPATH=\Documents and Settings\mand
LOGONSERVER=\\COMPUTER
NUMBER_OF_PROCESSORS=2
OS=Windows_NT
Path=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\system32\wbem;C:\Program Files\Intuwave\Shared\mRouterRuntime;C:\Program Files\Common Files\Adobe\AGL;C:\Program Files\QuickTime\QTSystem
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
PROCESSOR_ARCHITECTURE=x86
PROCESSOR_IDENTIFIER=x86 Family 15 Model 4 Stepping 9, GenuineIntel
PROCESSOR_LEVEL=15
PROCESSOR_REVISION=0409
PROMPT=$P$G
QTJAVA=C:\Program Files\Java\jre1.5.0_09\lib\ext\QTJava.zip
SESSIONNAME=Console
SystemDrive=C:
SystemRoot=C:\WINDOWS
TEMP=C:\DOCUME~1\mand\LOCALS~1\Temp
TMP=C:\DOCUME~1\mand\LOCALS~1\Temp
USERDOMAIN=COMPUTER
USERNAME=mand
USERPROFILE=C:\Documents and Settings\mand
windir=C:\WINDOWS
-- User Profiles ---------------------------------------------------------------
mand
(admin)
neel
(admin)
-- Add/Remove Programs ---------------------------------------------------------
--> d:\Program Files\Ahead\nero\uninstall\UNNERO.exe /UNINSTALL
--> MsiExec.exe /X{09959E11-AD5D-408E-96AF-E3346954D6B8}
--> MsiExec.exe /X{64F3B15C-24C7-4B2B-9B72-65CCBBD7F06B}
--> rundll32.exe setupapi.dll,InstallHinfSection DefaultUninstall 132 C:\WINDOWS\INF\PCHealth.inf
µTorrent --> "C:\Program Files\uTorrent\uTorrent.exe" /UNINSTALL
Adobe Bridge 1.0 --> MsiExec.exe /I{B74D4E10-1033-0000-0000-000000000001}
Adobe Common File Installer --> MsiExec.exe /I{8EDBA74D-0686-4C99-BFDD-F894678E5B39}
Adobe Flash Player 9 ActiveX --> C:\WINDOWS\system32\Macromed\Flash\UninstFl.exe -q
Adobe Help Center 1.0 --> MsiExec.exe /I{E9787678-1033-0000-8E67-000000000001}
Adobe Photoshop CS2 --> msiexec /I {236BB7C4-4419-42FD-0409-1E257A25E34D}
Adobe Reader 7.0.8 --> MsiExec.exe /I{AC76BA86-7AD7-1033-7B44-A70800000002}
Adobe Stock Photos 1.0 --> MsiExec.exe /I{786C5747-1033-0000-B58E-000000000001}
BlazeDVD 5.0 Professional --> "D:\Program Files\BlazeVideo\BlazeDVD 5 Professional\unins000.exe"
Canon Camera Access Library --> "C:\Program Files\Common Files\Canon\UIW\1.0.0.0\Uninst.exe" "C:\Program Files\Canon\CAL\Uninst.ini"
Canon Camera Support Core Library --> "C:\Program Files\Common Files\Canon\UIW\1.0.0.0\Uninst.exe" "C:\Program Files\Canon\CSCLIB\Uninst.ini"
Canon Camera Window DC_DV 5 for ZoomBrowser EX --> "C:\Program Files\Common Files\Canon\UIW\1.0.0.0\Uninst.exe" "D:\Program Files\Canon\CameraWindow\CameraWindowDVC\Uninst.ini"
Canon Camera Window DC_DV 6 for ZoomBrowser EX --> "C:\Program Files\Common Files\Canon\UIW\1.0.0.0\Uninst.exe" "D:\Program Files\Canon\CameraWindow\CameraWindowDVC6\Uninst.ini"
Canon Camera Window MC 6 for ZoomBrowser EX --> "C:\Program Files\Common Files\Canon\UIW\1.0.0.0\Uninst.exe" "D:\Program Files\Canon\CameraWindow\CameraWindowMC\Uninst.ini"
Canon G.726 WMP-Decoder --> "C:\Program Files\Common Files\Canon\UIW\1.0.0.0\Uninst.exe" "D:\Program Files\Canon\G726Decoder\G726DecUnInstall.ini"
Canon MovieEdit Task for ZoomBrowser EX --> "C:\Program Files\Common Files\Canon\UIW\1.0.0.0\Uninst.exe" "D:\Program Files\Canon\ZoomBrowser EX\Program\MVWUninst.ini"
Canon RAW Image Task for ZoomBrowser EX --> "C:\Program Files\Common Files\Canon\UIW\1.0.0.0\Uninst.exe" "D:\Program Files\Canon\RAW Image Task\Uninst.ini"
Canon RemoteCapture Task for ZoomBrowser EX --> "C:\Program Files\Common Files\Canon\UIW\1.0.0.0\Uninst.exe" "D:\Program Files\Canon\CameraWindow\RemoteCaptureTask DC\Uninst.ini"
Canon Utilities EOS Utility --> "C:\Program Files\Common Files\Canon\UIW\1.0.0.0\Uninst.exe" "D:\Program Files\Canon\EOS Utility\Uninst.ini"
Canon Utilities PhotoStitch --> "C:\Program Files\Common Files\Canon\UIW\1.0.0.0\Uninst.exe" "D:\Program Files\Canon\PhotoStitch\Uninst.ini"
Canon Utilities ZoomBrowser EX --> "C:\Program Files\Common Files\Canon\UIW\1.0.0.0\Uninst.exe" "D:\Program Files\Canon\ZoomBrowser EX\Program\Uninst.ini"
FileZilla (remove only) --> "D:\Program Files\FileZilla\uninstall.exe"
Folder Lock --> D:\Program Files\Folder Lock\Uninstall.exe
High Definition Audio Driver Package - KB888111 --> "C:\WINDOWS\$NtUninstallKB888111WXPSP2$\spuninst\spuninst.exe"
HijackThis 2.0.2 --> "C:\Program Files\Trend Micro\HijackThis\HijackThis.exe" /uninstall
Intel(R) Graphics Media Accelerator Driver --> RUNDLL32.EXE C:\WINDOWS\System32\ialmrem.dll,UninstallW2KIGfx2ID PCI\VEN_8086&DEV_2782 PCI\VEN_8086&DEV_2582
Intel(R) PRO Network Adapters and Drivers --> Prounstl.exe
iTunes --> MsiExec.exe /I{3592F5CB-B524-43AA-92F2-2377268199CC}
J2SE Runtime Environment 5.0 Update 9 --> MsiExec.exe /I{3248F0A8-6813-11D6-A77B-00B0D0150090}
m-Router 3.1 --> RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\PROFES~1\RunTime\0701\Intel32\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{A2092B2A-A4FB-4464-A4C0-023D2C9993F8}\Setup.exe" -l0x9
Megaupload Toolbar --> C:\Program Files\MegauploadToolbar\uninstall.exe
Microsoft Office 2000 Premium --> MsiExec.exe /I{00000409-78E1-11D2-B60F-006097C998E7}
Microsoft Office Access 2003 Runtime --> MsiExec.exe /I{901C0409-6000-11D3-8CFE-0150048383C9}
Microsoft Private Folder 1.0 --> MsiExec.exe /I{644EA08F-87D2-48C0-AE94-B327D1C85A97}
Nero Suite --> C:\Program Files\Common Files\Nero\Uninstall\setupx.exe /uninstall ExtraUninstallID=""
NOD32 antivirus system --> C:\Program Files\Eset\Setup\setup.exe /UNINSTALL
NOD32 FiX --> "C:\Program Files\Eset\unins000.exe"
Nokia Connectivity Cable Driver --> MsiExec.exe /X{B7757137-0A71-4A9F-8A82-1AE4A1B73420}
Nokia Multimedia Factory --> C:\PROGRA~1\COMMON~1\INSTAL~1\Driver\9\INTEL3~1\IDriver.exe /M{BD72E64C-F0DB-40CB-846B-611C57D8AB0C} /l2057
Nokia PC Suite --> MsiExec.exe /I{FF059F2A-62A7-4E6A-B305-559591D2769E}
Nokia Software Updater --> MsiExec.exe /X{447AC5D6-8520-4151-AECA-323C36507EFB}
QuickTime --> MsiExec.exe /I{08094E03-AFE4-4853-9D31-6D0743DF5328}
REALHOUND IP --> D:\realhndip\Uninst_REALHOUND IP.exe /U "D:\realhndip\Uninst_REALHOUND IP.log"
Realtek High Definition Audio Driver --> RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}\setup.exe" REMOVE
RECIPE ORGANIZER DELUXE (S) --> MsiExec.exe /I{B5A9399E-A38F-489D-BAB5-A14EDBE55E1B}
Rhapsody Player Engine --> MsiExec.exe /I{2DFF31F9-7893-4922-AF66-C9A1EB4EBB31}
Skype 3.1 --> "D:\Program Files\Skype\Phone\unins000.exe"
Switch Off --> "D:\Program Files\Switch Off\uninstall.exe"
Uniblue PowerSuite --> "D:\Program Files\Uniblue\unins000.exe"
Unlocker 1.8.5 --> D:\Program Files\Unlocker\uninst.exe
VideoLAN VLC media player 0.8.5 --> D:\Program Files\VideoLAN\VLC\uninstall.exe
WinDVR --> "C:\Program Files\InstallShield Installation Information\{6BF4613C-0A46-43AA-8FA8-0CB9F2C1A548}\setup.exe" REMOVEALL
WinRAR archiver --> D:\Program Files\WinRAR\uninstall.exe
Yahoo! Install Manager --> C:\WINDOWS\system32\regsvr32 /u C:\PROGRA~1\Yahoo!\Common\YINSTH~1.DLL
Yahoo! Messenger --> D:\PROGRA~1\YAHOO!\MESSEN~1\UNWISE.EXE /U D:\PROGRA~1\YAHOO!\MESSEN~1\INSTALL.LOG
YoutubeGet 4 --> "D:\Program Files\YoutubeGet\unins000.exe"
-- Application Event Log -------------------------------------------------------
Event Record #/Type14070 / Warning
Event Submitted/Written: 07/05/2008 04:34:30 PM
Event ID/Source: 1524 / Userenv
Event Description:
Windows cannot unload your classes registry file - it is still in use by other applications or services. The file will be unloaded when it is no longer in use.
Event Record #/Type14031 / Error
Event Submitted/Written: 07/03/2008 07:35:02 PM
Event ID/Source: 1000 / Application Error
Event Description:
Faulting application iexplore.exe, version 6.0.2900.2180, faulting module mshtml.dll, version 6.0.2900.2180, fault address 0x0012bd68.
Processing media-specific event for [iexplore.exe!ws!]
Event Record #/Type14030 / Error
Event Submitted/Written: 07/03/2008 07:34:39 PM
Event Description:
Event Record #/Type14029 / Error
Event Submitted/Written: 07/03/2008 07:33:53 PM
Event Description:
Event Record #/Type14024 / Error
Event Submitted/Written: 07/03/2008 04:12:45 PM
Event Description:
Faulting application iexplore.exe, version 6.0.2900.2180, faulting module kernel32.dll, version 5.1.2600.2180, fault address 0x0001eb33.
-- Security Event Log ----------------------------------------------------------
No Errors/Warnings found.
-- System Event Log ------------------------------------------------------------
Event Record #/Type30768 / Warning
Event Submitted/Written: 07/03/2008 11:43:34 PM
Event ID/Source: 4226 / Tcpip
Event Description:
TCP/IP has reached the security limit imposed on the number of concurrent TCP connect attempts.
Event Record #/Type30739 / Error
Event Submitted/Written: 07/03/2008 10:45:31 PM
Event ID/Source: 1003 / System Error
Event Description:
Error code 1000000a, parameter1 00000023, parameter2 00000002, parameter3 00000000, parameter4 804fccd6.
Event Record #/Type30724 / Error
Event Submitted/Written: 07/03/2008 10:36:40 PM
Event ID/Source: 7026 / Service Control Manager
Event Description:
The following boot-start or system-start driver(s) failed to load:
AFD
Fips
intelppm
IPSec
MRxSmb
NetBIOS
NetBT
nod32drv
RasAcd
Rdbss
Tcpip
WS2IFSL
Event Record #/Type30723 / Error
Event ID/Source: 7001 / Service Control Manager
Event Description:
The IPSEC Services service depends on the IPSEC driver service which failed to start because of the following error:
%%31
Event Record #/Type30722 / Error
Event Description:
The TCP/IP NetBIOS Helper service depends on the AFD Networking Support Environment service which failed to start because of the following error:
%%31
I just wanted to add 1 more query. I hope I am not troubling you too much with my questions. As soon as I switch on my computer I get a screen saying EPROM MISS. I have an external tv tuner card connected. After sometime it will start working if I try to check any connections or by itslf. But when that message is displayed I would not be able to do anything till it gets fixed. And when it works ,the whole screen monitor has the picture when I use TV. But when I change to computer mode, a very small part at the end of of the screen is not used. Is there any resolution problem. I have tried my best to explain the problem in words here. If you have any resolution, plz let me know. Thanks
