zeke1312 Member Jul 4, 2008 #1 I'm using Vista. How do I change my location files I download from the internet? They now download to the download folder. They used to download to the desktop (where I want them to go to).
alexyu New Member Jul 4, 2008 #3 To save a file to desktop using IE He's probably using IE To save a file on desktop with IE, follow theese steps: 1.Click the download link 2.Select SAVE 3.Click BROWSE FOLDERS 4.Select DESKTOP 5.Select SAVE The file has been saved to the Desktop. Last edited: Jul 4, 2008
thermophilis Member Jul 4, 2008 #4 haha, I realized, about two minutes ago that based on his post he was probably using IE and was going to do almost the same thing
Kesava Active Member Jul 4, 2008 #5 if you use firefox then you need to go to Tools -> Options -> Main -> change the setting in the downloads section. if your using IE then im not as sure...
Kesava Active Member Jul 4, 2008 #9 Tuffie said: This thread is good proof that FF shits all over IE. Click to expand... that was completely useless to say.. why bother? and how is it proof anyway?
