Command Prompt BROKEN!
FFCFoo
Whenever I type in anything into my command prompt it gives me this for example I type "ipconfig/all" It says this! "'ipconfig' is not recognized as and internal or external command, operable program or batch file." I think it might be disabled or something?:confused::confused:
It could be that your path variable is broken.
At the C: prompt type set and paste the path command in your next post.
If you type "Set" , no matter what directory, this will be displayed. Look down to the Path= and it should read what it says here, if it doesn't then your command lines won't work.
ehhhh
i couldn't either. one line and no spaces.
I dont understand lol here is a pic when I type "set"
:confused:
thats ok. ...... maybe its the operating system. im using xppro.
Dos is not to popular anymore anyway. Im curious, thats about it.
it worked for you.
cheers.......
