Xp question ?
colt1911
For sometime I've been dual booting with XP and Vista 64 and I've decided to go strictly with Vista . Is there a way to delete XP which is partitioned on the same drive as Vista without reformatting Vista as well ?
Open Start Menu -> Right Click Computer -> Click Manage -> Click Storage -> Click Disk Management -> Right Click the XP Partition and Select Delete.
To delete the XP option from the boot menu, Open Start -> Type Msconfig into the search box -> Click Msconfig -> Select the Boot tab -> Delete the XP entry
Just reformat that partition with Gparted
You can do it within Windows.
Come on guys.... remember the thread the other week about "all working together"? - Both good ideas/solutions, both result in the desired effect so well done ;)
Thanks for the info . I did it through windows and everything is fine . Once again I appreciate all of you for the help.
