[-0MEGA-];1021311 said:IDE is a form of ATA. IDE is also knows as PATA.
SATA is better then IDE/PATA, the interface is much faster, smaller cables, etc. The reason IDE is more expensive for you is probably because IDE is being phased out and quantities are more limited.
No problem, just make sure your motherboard supports SATA before buying a SATA hard drive.SATA it is then!
Thanks for the help, I am sure I will be asking a few more questions as I research what to build.
Every new motherboard should support it now.No problem, just make sure your motherboard supports SATA before buying a SATA hard drive.
Depends on the model, generally speaking the Intel's perform better however the Athlon X2's are great for their price.How about this one:
Intel Dual Core
or
AMD Anthlon X2
Is there a difference? One brand better then the other?
I know, I wasn't 100% sure if he was buying new or not though.Every new motherboard should support it now.
I know you know that, I don't know that dudemycar does though[-0MEGA-];1021387 said:I know, I wasn't 100% sure if he was buying new or not though.
