[-0MEGA-];1021621 said:That is disgusting.
Corey, you need to update your drivers only if your NIC doesn't show up in the device manager or the "Network Connections" page. If it doesn't show up, then you would go to the website for the manufacturer of your ethernet adapter (NIC), search for your model, and download the correct driver for your OS.
Not always, it depends on the OS really. Vista should have drivers for most NIC's, however if you have XP or earlier then you may need drivers - depending on how old the motherboard/NIC is.If it's built in the mother board drivers should work unless its a PCI LAN card.
[-0MEGA-];1021631 said:Not always, it depends on the OS really. Vista should have drivers for most NIC's, however if you have XP or earlier then you may need drivers - depending on how old the motherboard/NIC is.
It's the device that the ethernet cable plugs into.what a nic?
