Gaming computer build
a budget that low wont get you a 'gaming computer'. If you just want to play WOW and older pc games id still suggest a higher budget
Somehow I doubt that. I have a single core 3.4ghz processor with a 128mb graphics card. I can play wow with moderate lag. Now if i could get a dual core, better graphics card, more ram then it would run like a pro.
Yeah, i've been speaking to him on msn, and he is only 13, so he can't get money quickly really....
Ok the thread has been changed. Instead of me asking for a build here is a build that i would like comments on (what should be changed, what is needed, what isn't compatible, etc.) Thank you, Halofreak
MST problem
Consider a undirected graph, G(N,A), where N and A are the set of nodes and arcs (edges), respectively. Associated with each arc (i,j) in A is a cost c(i,j). Let |N| = n and |A|=m. The problem is to find a rooted undirected spanning tree, G(N,S) where S is a subset of A such that the sum of c(i,j) for all (i,j) in S is minimized. The rooted undirected spanning tree is defined as a graph which connects, without any cycle, all nodes with n-1 arcs, i.e., each node, except the root, has one and only one incoming arc.
You are required to read a graph from a text file. The first 2 numbers (N and E) in the text file specifies the number of vertices and the number of edges available. Follows are the E lines each specifying a link between 2 nodes.
The problem is to find a minimum spanning tree.
Sample input:
8 10
0 1 9
1 3 7
2 3 15
3 4 10
4 6 8
4 5 3
5 6 14
1 6 5
6 7 6
1 7 12
Sample output (The sum of the weights of the spanning tree edges)
53
Intel E7200
Gigabyte GA-P31-S3G
OCZ Platinum Revision 2 2 x 1GB DDR2 800 OCZ2P800R22GK
GIGABYTE GV-NX88T256HV1 GeForce 8800 GT 256MB
Seagate Barracuda 7200.10 ST3250410AS 250GB - OEM
SAMSUNG 22X DVD Burner Black SATA Model SH-S223F - OEM
Antec earthwatts EA430
Case: choose your own, assume $50
$543, MIR$85 = $458
By the way, You'd better buy CPU after 20/07.
OK, Here we go:
Total - $415.93
I see you updated your original post, looks good, i have changed a few things in it.... with a video card + power supply.
Yea but im 13 lol and also I didn't want to really have you make a build just tell me whats wrong with mine for future reference. All thought I do completely appreciate your efforts.
Yea I'm 13 lol so I can't afford much. But I didn't exactly want you to make a new build just tell me whats wrong with mine for future reference. Although I do completely appreciate your efforts.
Better not say your age, otherwise PC_I will ask for your myspace, haha
