There all the same. what features do ya want. Truth is i always built on it.
Nice features and a simple edit will allow usb support. everything else like commands i just copy to the boot. what about reading ntfs in dos. do ya need to edit and delete? ntfsdos sets up a server side. they all do the same. build on it. let me know what ya want.
Cohen......off the top of my head.
Copying would be better done in windows. i never did in dos. Maybe you could do in safe mode. not sure. a soft cloth across the grain of the cd. blow out with static free air on the burner. (soft). im not familar with the dos ram test though. take your boot and copy them to the boot. if there is any special configurations for the autoexec or confiig sys then incorporate them into the boot using and saving with dosedit. If burning with your software which i exclusively use Nero you can chage the burn rate to 2x. If you need usb support for dos look for drivers from panasonic. this is whip asss when ya need usb. Also ntfsdos. the free will allow you to read ntfs. the ntfspro ver will allow you to rite. sorry if this didnt help. my best shot. you helped me often enough.
thanks for the support.
tremmor
If ya want a boot.........this is the same.
add what ya want to the boot. its as good as it gets.
build it. not one will have everything ya want.
wing it. its an adventure. make it, tune it for you.
cheers
