show me the best computer on the market!
AmdRadeonUser
i have a half decent rig, amd phenom 2.2ghz*4, 4 gigs of ram ddr2, 500gb hdd.
now I want to know whats the best on the market, i want to see the best build as of this date july 19 2008
edit : also have a 512 radeon 2600
skulltrail rig with two ati 4870's with 8gbs of server ram while running 16 ssds in raid zero and two bluray/hd dvd/dvd/cd burners with 3 30" dell moniters at a resolution of 2600x1900
IBM’s Blue Gene/L supercomputer is the fastest in thw world as of 2007 and is in the US but it isnt the most expensive its only 2 mil while a Super computer built by the Japanese was priced at 400 mil in 1997. Pretty sure you didnt mean for "super computers" but if you have 2 mil then your in luck lol. And im bored so yea lol.
seems to me some researchers put together 4 9800 gx2's that beat that out, which does figure since thats 8 cores with how many actual processors
maybe i shouldve been more specific, im not looking to buy, I want to know what the best computer in the world is as of this date, i want to see it and know the specs :)
thanks for the reply's though, I would definitely take the two gddr5 512mb radeon then the 3 gtx 280 in sli
read my name
zomg justanoob, that celeron clocked at 450mhz is a beast!!! no wonder why it can run crysis at max, 32mb of ram? you spoiled little bastard.
it didnt beat out IBMs computer. it beat out the "more powerful computers" that hospitals generally use for advanced radiological imaging.
supercomputers are tops. That IBM is the best.
But, realistically speaking, something that you can actually get, it would be:
1 x Intel Skulltrail mobo
2 x Intel Core2 Extreme QX9775
8 x DDR2 800 (FB DIMM, basically better than DDR3 cause it reads and writes at the same time)
2 x 4870 or 4870X2 when it comes out (the skulltrail supports only crossfire so SLI is out)
1 x 1200W or more PSU (not too sure)
1 x Windows Vista (this system can run it well)
Enjoy the rest of your life in poverty, with a super-computer (that the "common" man can have access to)
