Yea thanks didnt look at ALUs on the processors usualy. I dont get why the intel Core 2 that has lower clock speed and the same if not less l1 and l2 cache and are more expensive are they that much better? I been using an AMD processor for a while know so i havnt been keeping up with intel.
So Windows XP Service Pack 2 is better than Service Pack 3?
because Intel are doing what AMD did before
in the past (single core days) AMD chips were faster in practice, but much slower in clock speed (an 2.4 athlon would be the same as say a 3ghz Pentium 4). This was as they were more efficient
More efficient chips are the way to go, and Intel went that route with the Core2.
You use the amd 4600 is it good for gaming?
I was looking at the amd 6000 will it be able to run games like crysis with maybe a 8800gt or will it slow down performance?
The Core 2 Duo E7200 is better than AMD 6000+. Moreover it consume much less power.
If you are going to build a new computer then get E7200
