i aquired a HP Pavillion m7350n desktop and have the recovery disk. I want to just start from scratch with it. How do i go about erasing everything and using the recovery disk to get windows and other main programs back on the computer? Thanks!
you can just put the pisk in, start the computer up. hit F12 of delete or esc key right as you turn the power on and then select the dvd drive and hit enter. then just follow the instructions and it should reformat and reinstall
