New rig for cheap family member
James^.^
I'm building a new pc for a family member and am trying to save as much money as possible but also make it good for some gaming
1. Case
2.Mobo
3.Processor
4.HDD
5.DvD burner
6.RAM
7.GPU
8.PSU
Will this be able to run Unreal tournament and COD4 on highest settings with a good frame rate (about 40 fps) ?
http://www.newegg.com/Product/Product.aspx?Item=N82E16814122049
This video card is faster
Don't waste your money on an expensive memory like 4GB ram, just get 2GB ram and it will be more than enough
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227139
And since the 2GB ram will save you money, you can now spend the rest of the money for superior processor like Core 2 Duo E7200. The CPU will make more difference in gaming, and you could upgrade your RAM at any time in the future but for the current games the 2GB is really more than enough
Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138122
CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115052
Going the intel route adds like 100$ to the equation cuz of the motherboard and the processor. Any more ideas? anybody here use AMD? It has to be usefull for something (I'm pretty sure for cheap but decent cpu's)
PS. Didn't mean to double thread, but I keep getting this weird lag were it sends me to this blank page with two adds on it, so i go back a page and resend the info. next time i go back a page and refresh.
PS! I'm sorry that I double threaded but I keep getting this page that is blank with two adds on it and it sends the information sometimes and sometimes it doesn't so I sent the information again after i went back a page then i got a duplicate thread. (in fact i just had to write this whole paragraph again because of this problem)
EDIT
SEE IT JUST DUPLICATED H-•1§♣K►y5τa48▲ÄN╝I├ GAY
O yeah that makes sense to get, especially sense it has a higher clock, but anyway...
do you think this processor will be able to run Unreal tournament, COD4, and maybe Gears o war on high settings with a hd 3870?
The ones i mentioned, i can almost guarantee it, they play it on high, if not max settings. the 3870 is agreat card after all. But, usually a nvidia card gets more fps than a ati one.:o
What about this
Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138116
CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116052
If you can spend more you can get E7200
Higher clock doesn't mean anything when you compere Intel to AMD. A lower clocked Intel CPU can beat a higher clocked AMD CPU. For example E7200 is faster than AMD 5800+ despite having lower clock speed
Go my way... Purchase A AMD Black Edition @ aroun 70-80 $, and get a ECS 780G Black Ed.... and shound be around 140... thats perfect for family, i'm into gaming to I o/C my Black Ed to 3.2...:D
I recommend getting an Intel E2180 CPU and one of the P43 motherboards. You can also get E7200 if you want. The Intel CPU's perform very well even if you don't overclock.
