Hijackthis
Yep - internet won't work even with it plugged in. The reason I unplugged the ethernet cord in the first place was because someone told me that the virus on my computer (if there was a virus - I don't know the cause of my computer's internet not working, but someone suggested it was a virus) could travel through my ethernet cord, into my router, and to the other computer (my dad's) plugged in the router as well. My internet stopped working even while I had the ethernet cord plugged in.
Yes some viruses can do that, the only other thing i can suggested is your reformat......
Or try a easy thing i'm not too familiar with virus fixing, and combo and what not, but i think you should Start>Run> MSCONFIG, and stop all your normal start up programs, then check wether your internet is working, and from that point if it's working then it's maybe a virus....
So is there no other way to fix my computer? =/ Maybe I should just buy a new notebook..
I already did that wayy back when I didn't have a virus so my computer would start up a lot quicker. Thanks for the help, though!
Or restore point to the time the computer was actually connectiong to the internet like it should...
? I don't understand..
I mean use system restore... and find a restore point that goes back to when the computer didn't have the virus, and was connected fine..
