broadband modem
ivenn
i'm trying to connect my other laptop to my broadband modem. but wehn i pluged in the cable, it showed nothing . tried insert the modem cd, but it always says the cable is not pluged in even tho i checked several times. what is wrong?
um window vista n i have tried to update the modem driver , not sure if thats the one. where can i find it? :confused:
Have you checked that the ethernet port is enabled; both in your computers bios and in "Network Connections"? Is it installed correctly? Does it show in Network Connections?
If you can publish some details on your computer / lappy in question - i.e brand and model, then i'll happily find the correct driver for ya.
the vista version is weird. ive checked the cable its enabled, .....
my laptop is toshiba satellite U200.
thanks guys i really appreciate it :o
