Dangerous Toys
If I raise the multiplier on my CPU, do I need to raise the voltage as well? If so how do I know how much to raise it? Do I also need to raise the frequency on my memory?
Im using a zerotherm cooler and temp is at 32.7C right now. The cpu is a Intel Core 2 Duo E8400 3.0 Ghz. the default on the motherboard was a multiplier of 7 at 333.34 Mhz Bus speed which was only giving me 2333.38 or 2.33 Ghz so I raised the multiplier to 9 which gave me 3000.06 Mhz (3.0Ghz). Out of the blue the computer randomly shut down. And thats when I was only web surfing. If I played a good 3D game she ran fine. So for giggles I raised the cpu voltage by 0.0125 volts and now shes running like a champ. What would be the cause for that? And did I do the right thing just to get my cpu to run at a stock core speed?
Speedstep is disabled. I had power option set to sleep in 1 hour. I changed it to never. I have vista home premium 32bit.
Speedstep and/or C1E lowers the multiplier and voltage, if only Speedstep is disabled then it's possible that C1E is still enabled.Speedstep has to be kicking in or your X would not have been at 7 for you to raise it
If the multiplier is set lower then stock, then I wouldn't consider that being able to raise the multiplier, as you aren't raising it higher then stock.My motherboard is a MSI P6N Diamond SLI 680i. In the Bios i can raise or lower the multiplier but only to reach the stock core speed. If I want to overclock I can adjust the FSB clock or Memory clock or I can enable the D.O.T. (Dynamic Overclocking Technology) which I can adjust by percentage.........
Did you check C1E?I checked again and speedstep is definetly disabled, at least it says it is.........
I believe we both forgot to mention that, there's no harm in leaving those settings enabled, the processor is still going to run at it's full potential. It will simply run cooler, use less electricity, and last longer when you don't need the full processing speed of the CPU.You can leave them both enabled, when you run a intensive program or fire a game up the CPU will jump back up to stock settings.
It varies with the motherboard, it may either be under the Power settings as StrangleHold suggested, or it could be under the Advanced settings page.I dont want to sound stupid but I am new at this. What is C1E and where do I look in Bios for it?
