GrungyHobo
I'm looking to get a laptop that will be good for gaming, it doesn't need to be crazy, I just want it to be able to handle games like unreal tournament 3. So what should I look for? Brand, CPU, RAM, HD, GPU, etc...???
For $1500 you can get specs similar to the Laptop thats in my Sig.
[-0MEGA- said:]I'd get a Core 2 Duo 2GHz+, 3-4GB RAM, 250GB HD 5400RPM+, 8600M GT/3650 or better - which can all be found for under $1000.
It is, but usually with mid-ranged gaming laptops the GPU is more of a bottleneck, if you can get a 2.2GHz C2D or better though then that would help out a bit.2ghz is a little low for games like cod, I would recommend a 2.2+ghz c2d, atleast 2gb ram, a 7200rpm hard drive or a large 5400rpm hard drive, and atleast an nvidia 8600m gt.
