I just downloaded CPUZ and it said my CPU is running at 1.2 volt, is it meant to be that low? the only oc i have is the core speed and the multiplier, is it safe to increase the voltage by a small amount ?
Thanks
sorry to jack the thread, but, if you'd take it one or two steps above the factory setting (like, mine was at 1.4v i believe) and that'll give a good chance of stability on @ 3.2ghz. any higher than that and the power consumption and heat just rocketed for me.
