8x9800GX2! MIT researcher build 16 GPU monster-class computer
While poorly coded games gain no performance at all in SLI, and a bit of optimization is needed to get the most out of a SLI-setup, games don't need to be actually "multithreaded" to support Multi-GPU setups. It doesn't work exactly like when you have multiple CPUs/Cores and you need to make your applications multithreaded to see the full potential of your system. Also, I've seen that you're no big fan of Multi-GPU setups, but with recent advances in technology SLI/Crossfire bring pretty impressive gains on many games/applications, way, WAY better than back when those technologies were introduced.
SLI/Crossfire is parallel processing. So, all you get is raw data throughput. Not as advantageous as multi threading the processes out. Waste of money, unless they are rendering like a 10 TB file or something.
they are probably using this for medical research like those other guys who did something similar (vague, but i dont feel like searching for the source right now)
they used it to render medical images
