D-link router problem
victorti83plus
Hi,
My friend's router works fine until today, there is no internet connection. The wan light is on, but the other port1-port4 have no light. (He connects two computers in port 1 and 2, 1 is connected via wireless and the other is connected with a wire.). And he can't access to 192.168.0.1 neither.
I'm suspecting his router is defected....Any idea?
Okay im sure the cable/dsl is fine w/o the router
SO you have the Cat 5 wire from the Cable/dsl to the incoming port of the router correct? From this you have the slots 1 and 2 with cat 5 wires to other pcs?
If so try unplugging and waiting a minute... first the cable... plug back in and then the router...
You may be way past that already but I just needed to double check
Matt
Matt
Yes I did all that. And you are right, cable/dsl is fine w/o the router.
huh.... so wireless and lan both dont work.... I had a problem like this... I just kept resetting the router... rebooting the PC.. routers are a pain in the ass
