okay price drop!!!
Instinct5
Well originally had in mind to build an expensive gaming computer but now i need something cheap but still good budget i dont want to go over 700. Ill be playing basic games like CS:S, TF2, COD4, BF2, I want a computer that can run these games no problem im sure these games dont need extreme requirements. I need everything OS, DVD dirve. as for a case it might be cheaper to find one with a PS. I basicly want a case with a window and blue LED lights. All help and suggestions will be greatly appreciated. I have attempted builds but i cant manage to keep it under my budget. Thanks in Advance
oh geez my sig that was my frist gaming computer had to sell it cause my parents needed money :( ill remove it
E7200
MSI P43 Neo3-F
OCZ Platinum Revision 2 2 x 1GBDDR2 800
ASUS EAH4850/HTDI/512M Radeon
Seagate Barracuda 7200.10 ST3160815AS 160GB
SAMSUNG 22X DVD Burner Black SATA Model SH-S223F - OEM
Antec Sonata III 500 Black
Vista Premium OEM
these should come with approx $700 with MIR at newegg
This is my attempt came to $698.93 Please tell if things are not compatible or things that i can better that wont hurt me financially. All help is wanted
Video card
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=3749879&sku=B52-9606
Operating System Vista home premium 32-bit i dont need anymore then 2gb of ram so 64 bit isnt necessary.
MotherBoard not sure if this will work with CPU
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2968644&sku=A455-2346
RAM
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2882686&sku=O261-8070
HDD if i need to in the future i can upgrade size.
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2937363&sku=TSD-160AS5
CPU i went with this one because its cheap i had the 5200+ and had no problems whatsoever
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2905653&sku=CP1-AM2-5400
Case w/ PSU
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=1289171&sku=A406-1028
Antec Sonata 500W is an antec sonata III case and antec earthwatts 500 watt power supply
what my build doesn't have is an optical drive but yours didn't either so i figure you had an extra one.
3870=9600gt<8800gt=9800gt<4850<4870
k what this means is? get an 8800?
According to his little chart, he's saying that the HD4870 pwns all. What about the GTX 280? or am I buying into that a little early :P
3870=9600gt means an 3870 is roughly equal to a 9600gt.
9600gt<8800gt means an 9600gt is beaten by a 8800gt.
using the the transitive property, an 8800gt beats an 3870.
here is the chart a little more filled out.
HD3870=9600gt<8800gt=9800gt<8800gts(g92)<9800gtx=HD4850=9800gtx+<gtx260<HD4870<gtx280
k i think i got er thanks for clearing that up. Im going to pick a 4850 I hear lots of good things about them they are cheap and i think ill like it
