Iced_Bullet
Recently, I bought my new PC which I am very pleased with =]
I only have 2gb (2x1gb) of RAM and with Vista it might need to be upped soon by either 2gb or 4gb.
It says in the Mobo instructions that I have to have the 'Same size and type in DIMM 1 + 3' and the 'Same size and type in DIMM 2 + 4'. Does this mean I can have 1gb sticks in DIMM 1 + 3 and then 2gb sticks in DIMM 2 + 4?
Also, the current ones are these - http://www.scan.co.uk/Product.aspx?WebProductId=402849 800mhz CAS 4-4-4-12
Can you suggest others? I could only find Corsair 5-5-5-14 2gb 800mhz sticks on Ebuyer or SCAN of the same visual style (dunno if that matters) ... does this number difference matter?
Also, could you suggest (find) some more pleeeeaseeee =] Any price at the moment ...
