compare 'n' selection of graphic card
linkaura
please tell me which one is better for these 2 graphic cards, i mostly use for gaming and illustrator sometime.
1)Sapphire Radeon HD 3870
2)Gigabyte Radeon HD 3870
are both of these g.cards use ATI? whats the different of these 2 g.cards?
which one should i take?:confused:
they're the same cards just under a different manufacturer. it depends, if one manufacturer overclocked the card and has a better warranty then that would be the better card.
Well as most people will tell you, it would be worth it to spend a little extra to get the HD 4850 because it is much better than the 3870.
And if you HAD to get the 3870, I would get the Diamond (It seems to be a little better all around than the rest).
Or if it had to be between those two, get the Sapphire, it's a great company ;).
True. It's been said a thousand times, and nowI say it again, it's one of the best performers for the value currently out there, it's well worth the little extra price over the 3870.
