Puff of smoke, need help lol
err76
Well I finaly got the new computer together and went to power it up for the first time, Heard a zap sound, big puff of smoke, the fans are running and also on the video card bot the mother board light tree is lit up red and i get no signal to the monitor. I went through the instructions slowly when it came to the wiring and everything else was straight forward.
Any guesses?
Could you tell where the smoke came from or if anything's fried on the board? My guess is either you shorted the motherboard on the case (IE no standoffs, grounding it to the case) or the PSU failed.
Did not see the smoke. Power supply fan is running but now the processor fan is not along with one of the case fans. If by the standoff's you mean the brass things under the MOBO, yes they are installed.
This is exactly why I should have bought one, lol
Ok, dug around the box a little and found,
Power supply to all of the fan wires are chared completely through the insulation, I am assuming that the power supply is fried.
My question is, is there a possibility that the mother board or processor is fried. Jeesus that thing is tied into my video card too. how do i check these things?
The best thing now would be too 'borrow' a friends supply and just plug in the essentials into your comp. If you get past the POST beep, your motherboard and CPU should be good. And see if you can load into your OS *hdd's should be connected*. IDK about ur vid card though.
PSU to fans? Were these the only wires that were burnt? I'm still wondering if there's something else wrong in the case to case everything like this to short out...
Be careful when testing the hardware. I have seen bad motherboards ruin good PSUs.
The psu was a 650watt corsair power supplu unit. As far as I could tell the only wires that were destroyed were on the i guess you would call it on the accessorypower lines, it has 4 power connector's at the end it has the power conector for the floppy drive. After I saw that I was pretty pissed and stopped looking around in the case as I figured that I fried every dam thing in that case. I am going to get on the line with newegg in a couple and start tearing it apart, I need a new PSU at the least. I hope it was just the wires that shorted out.
These were the only ones burnt up, yes.
As far as I could tell the mobo is intact, I do not see any chared marks on it but I dont have access to the back of it either.
Well, I just got off the phone with newegg. They suggested that I bring the power supply and the rest of the assembled computer to the Bestbuy geek squad and have them run a full diagnostic on it to see what is fried and what is not. After that they will give me RGA numbers to send whatever is fried back.
Putting it together was quite simple. I hope this thread does not discourage anyone, I think I just had a run of bad luck with that power supply.
I still find that rather strange how only the fans were burnt... Were you using any type of controller? Perhaps something that could have been connected backwards?
As for Geek Squad, I normally discourage the use of place like that... They are typically very overpriced and usually don't know what they're talking about. I should know, my roommate last semester worked for them... However, they may have the equipment avaliable to test what you have without destroying other stuff :P
Not sure, the only wire that was burnt was the accesory plugs for the fan and floppy disc connector.
Took it to Best buy and they put a power supply on the computer for me real quick and the guy was saying that everything is good to go on the motherboard side, nothing is charred, getting power to all the plugs and capacitor's. I am going to order one tonight and hopefully get this thing up and running by Thursday.
Thanks for all of the help guys, I appreciate it.
