Timmorgz78
I have recently bought a new computer with an Asus P5GC-MX 1333 motherboard, It came with 2GB of DDR2 533 (PC2-4200). These are the specs that I have found on the Motherboard
Chipset: Intel 945GC
Supported DRAM Types: DDR2 SDRAM only
Module Types Supported: Unbuffered only
Error Detection Support: Non-ECC only
Graphics Support: PCI Express x16
Max Component Density: 1024
USB Support: 2.x Compliant
240-pin DDR2 DIMM Banking: 2 (2 banks of 1)
DDR2 SDRAM Frequencies: PC2-3200 and PC2-4200
Max Unbuffered DDR2 SDRAM: 2048MB
I'm looking to upgrade the ram, but is it true that my motherboard can only support 2gbs? (Don't know if this should go in the motherboard section) But even if that is the case would a DDR2 PC2-5300 running at 667 at the same GB's have any great impact on the performance. I am really just using the computer as a MMO RPG gaming computer. Would it also be possable to put in 4GB's even though some of it might not be used?
Thanks for any help you can offer
