Secondary screen question
Take a look at Ultramon. thats what i use. im looking at
it but there are two many options. im sure its in there.
Im using duel 24" wide.
Ultramon crashed my Vista due to it being a beta driver ,
But Multimon is a freeware version which does a similar job for dual/triple/quad monitor setups .
You can do it if you right click on the taskbar (in a blank space), uncheck "Lock the Taskbar" then you can drag it freely to any position (top,bottom,left,right) on any monitor.
Im using XP Pro
I never said you wern't... but you never asked the original question and if you check the OP's sig- you will notice he's using Vista Premium and so I felt obligated to warn him of Ultramons beta Vista driver.
i tried it Lee101
didn't work for me. i do think the software i mentioned allows this on both
monitors. though i have and using one primary. Now im curious. why can't i.
cheers.
I going to take a look at this free software. thanks.
Why and who uses triple or quad monitors i will never know.
two duel 24" is enough. i have a table 12' long and using 17 usb ports
and some of my sheet is sitting on the floor.
i need a bigger house. thanks SQ1......
you don't get a second start menu in ultramon, just another taskbar if I remember correctly
Programmers/Coders or architects would probably benefit from triple screen setups IMO
But this is quite impressive:-
It's not my setup mate;)
I'm happy with dual screens, at the moment;)
URL%5D
IMG%5D
me too.. im getting ready to retire now. I have a new adventure with computers. (duel monitors). i bought a Nikon dedicated scanner for slides and negatives. i can edit on one screen and see the original on the other.
and then using Softice symbolic debugging and watching the output on the other.
thanks but is there a way to have a start bar on both screens?
I find dual monitors very useful. Especially when making/burning/downloading cd's because i need to open limewire and have another window open with the songs of the cd i want etc...
Here's my screen. I want to replace the white screen with a 22" or 24" wide screen and use that as my primary and use my 19" as the secondary
I use four 22" LCD monitors.
I started with two, for better multitasking, upgraded to three when I was a stockbroker, then after retirement I added a fourth so that I could game across thee monitors and monitor other tasks and program on the fourth.
Why settle for:
When you can have:
