you would be surprised how many performance freaks must have those extra frames/second, but from what i've heard the scaling between two of them isn't all that great in some games, i think makers will eventually have to limit them, its said that the largest psu available in the U.S. they can make, is an 1800 watt unit, otherwise, it will constantly trip your house's circuit breaker, otherwise a dedicated line will be required
Yep I am not sure if its worth it anyways,I guess if you have a 2500 x1600 res 30 " you might have to to max games like crysis.I hate having to think of buying 2 of the same cards for 10% more performance,not worth it myself.I guess you could always put in a 220 volt line for the high wattage PSU's,LOL.Getting outta control I think myself.They need to make the GPU's more energy efficient.I am planning on moving up to 1900 x1200 res.I think a single HD4870 X2 or GTX 280 might be good for that resolution could probably max 95% of games out there.I wonder if they started producing more multi core dependent games if that would take some strain off the GPU?
[-0MEGA-];1051469 said:Where does it say a minimum of 1KW? My entire system uses 533W according to the PSU calculator at almost full load, you may be able to get by with an 850W, then again though they are almost up there with 2KW PSU's, but if anyone needs that much power their electric bill would be huge!
YES THEM CARDS WOULD BE good enough for that res but why get the GTX280 for halve the price you cud get a 4870 witch is only 1% slower than the GTX 280
sorry off topic
