Should i make an upgrade to my current CPU?
Emuloverz
ok, sorry guys i been making a lots of posts and asking many noob questions:
now this question is about my CPU, i loved it, run games like crazy and i loved it. But now i want to make an upgrade to my current CPU.
This is My Current CPU: Intel Core 2 Dual E6550
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115030
Do you think i should make an upgrade to a better CPU?:
Two i have in mind is the:
Intel Core Quad Q6600
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
OR THE
Intel Core 2 Quad Q6700
Do you guys think that i should upgrade my CPU??
I have another question guys, i have a water cooling system, the problem is that i only have 2 tubes the run back and forth, one goes in the CPU and one goes out, but i want to use water cooling for my memory and graphic card too,is there like a way that i can split the Tube IN in to more then just one way?
i'd go for the e8400 or an e9550 right now.
but i don't see the use in upgrading right now.
i run an oc'ed e6420 and it's all i need.
Hey, hmm the q9550 is quit great, hehehe, i need some help, i heard people can overclock the e6550 like crazy, but i dont know how, can you help? BTW great computer you got there, so clean, hehe no wires, my computer have wires everywhere. hehe.
This is what im runing.
Case - Antec 900 Mid
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021&Tpk=Antec+900
Power Supply - Antec True Power Trio 550W ATX12V Power Supply with Three 12V Rails
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16817371002
MotherBoard: XFX MB-N780-ISH9 LGA 775 NVIDIA nForce 780i SLI Intel
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16813141005&Tpk=Xfx+780i
Cpu: Intel Core 2 Duo E6550 Conroe 2.33GHz 4M shared L2 Cache LGA 775 65W Dual
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115030&Tpk=intel+e6550
Cooling: Thermaltake Bigwater 760i 2u Bay Drives
Link: http://www.xoxide.com/thermaltake-b...tid=thermaltake-bigwater-760i&channelid=PGRAB
Graphic Card: Evga 8800 GTS 512MB
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16814130337
Hardrive 1: SAMSUNG 160 GB, 7200 RPM, SATA-II
Hardrive 2: Wester Degital 120 GB SATA 3GB/Sec
Hardrive 3: Wester Digital 500 GB SATA 3GB/Sec
CD/DVD/BURNER/DL BURNER
1 - Asus- dvd/cd/dvd dl/lightscribe Burner
2 - Sony- dvd/cd/dvd dl/ burner
3 - HL-DT-ST DVD-ROM 16x/52x DVD-ROM
Memory
1. Crosair - CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800
Link - http://www.newegg.com/Product/Product.aspx?Item=N82E16820145590
2. Crosair - CORSAIR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model TWIN2X4096
Link - http://www.newegg.com/Product/Product.aspx?Item=N82E16820145184
if you want to watercool more than one thing, you simply take the output of that block, and hook it to the input of the other block, that you want to hook up
I have an E6550 in my spare rig and I have clocked it to 513X7 for 24/7 use.
IMO you could easily clock it to 3-3.3 GHz and have a lot faster setup than you do now.
yea we tried to overclocked it, but i think the RAM cant handle overclocking.
did you talk to error about your overclock man? i plan on getting your proc to do 480x7 or better because my old e6300 had a x7 multiplier and i got it to 480x7. i can't see why your proc cannot handle that, maybe if we can get our hands on some D9 for you you will hit at least 450x7.
make sure the memory muliplier is set to by 2 and run your processor at 400X7
the memory should run 800 no problems, and I bet it will even run a little faster. Maybe your RAM multiplier is set to 2.4 or some high number right now.
An how you doing? no i havent talked to ERROR, i havent talk to you either, how about tonight we play some source?
@mikesrex thanks for the advice, i will try that
we can hit up some source late when i get back from my friend's birthday party. hopefully i'll be drunk so hilarity can ensue.
