ceewi1
Much better, but still a few more things.
Please delete the following folders:
C:\Documents and Settings\DB\!
C:\CDFix
I notice that the Kaspersky report is flagging
C:\Eset.NOD32.v3.0.669.Antivirus.Business.Ed.rar as infected. I can only assume that this has been downloaded from a less than legitimate site, and I suggest you delete that file immediately. If the program was not purchased legally, I also suggest you uninstall it and install one of the legitimate free programs mentioned in my last post, or purchase a legitimate version.
Please run Notepad and paste the contents of the codebox into a new file. Please do not include the word Code:
Save the file to the desktop as fix.reg and make sure the Save as Type field says All Files. Then please go to the desktop and double-click on fix.reg, and click Yes to merge it with the registry.
Please click on Start -> Run. Type ComboFix /u and click OK.
Note the space between the ComboFix and the /u
This will remove the backups that ComboFix has created as well as the program itself.
With regards to the Nokia suite, I suggest you first try completely uninstalling it and reinstalling it from the disk. Please tell me if that fixes your problem.
C:\CDFix
Code:
REGEDIT4
[-HKEY_CURRENT_USER\software\microsoft\windows\currentversion\explorer\mountpoints2\{40568082-2594-11dd-9eb4-000b7d18708b}]
[-HKEY_CURRENT_USER\software\microsoft\windows\currentversion\explorer\mountpoints2\{fd602d6c-dfb8-11dc-9e45-000b7d18708b}]
