Building A Computer: Halp Plzz.. Im new...
scorp
Hey All, I'm New At all this Computer Building stuff, but I've Basically Grownup with computers and always wanted to build one... I've Helped people build one but I havnt built one completely by my self, not have I chosen the Building Parts, so I hope yall can help me at this. I've looked for the stuff that I want in my Comp, but I dont know if they good or bad, or if they work along eith eachother... here I go...
BTW, THIS IS FOR GAMING!
Case: Antec Nine Hundred Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021&Tpk=Antec Nine Hundred
Power Supply: CORSAIR CMPSU-750TX 750W ATX12V / EPS12V NVIDIA SLI Ready ATI CrossFire Ready 80 PLUS Certified Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
Graphix Card:NVIDIA GeForce GTX 260
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130370
Mobo:EVGA 132-CK-NF78-A1 LGA 775 NVIDIA nForce 780i SLI ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188024
Ram:mushkin 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820146726
CD/DVD Drives: Sony NEC Optiarc Black 16X DVD-ROM 48X CD-ROM IDE DVD-ROM Drive Model DDU1615/B2s
http://www.newegg.com/Product/Product.aspx?Item=N82E16827101131
LG Black 16X DVD+R 8X DVD+RW 4X DVD+R DL 16X DVD-R 6X DVD-RW 16X DVD-ROM 40X CD-R 24X CD-RW 40X CD-ROM 4MB Cache SATA Super Multi Blu-ray Disc Burner & HD DVD-ROM Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136133
LITE-ON 20X DVD±R DVD Burner Black SATA Model iHAS120-04 - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106263
Hard Drive:Western Digital Caviar SE16 WD5000AAKS 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive
http://www.newegg.com/Product/Produ...ern Digital Caviar SE16 WD5000AAKS 500GB 7200
KeyBoard / Mouse:
Logitech MX518 2-Tone 8 Buttons 1 x Wheel USB + PS/2 Wired Optical 1600 dpi Gaming-Grade Mouse
Saitek PZ30AU Black USB Wired Standard Eclipse Keyboard
Processor:Intel Core 2 Quad Q9450 Yorkfield 2.66GHz 12MB L2 Cache LGA 775 95W Quad-Core Processor
http://www.newegg.com/Product/Produ...l Core 2 Quad Q9450 Yorkfield 2.66GHz 12MB L2
Additional Cooler (If Needed):CoolIT SYSTEMS EL-1000 Eliminator Thermoelectric CPU Cooler
http://www.newegg.com/Product/Produ...5227001&Tpk=CoolIT SYSTEMS EL-1000 Eliminator
Looks good so far...although I would certainly get a better power supply.
Especially if you want to add another gpu down the road...look in the 600W-750W range. Great variety, reasonable prices, excellent performance.
hahaha your crazy if you think that 430W PSU will run the 260.
You will need at least a 600w psu
  1. NNNNNNNNNNNNNNOOOOOOOOOOOOOO !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  2. AMD Motherboard + Intel CPU = WON'T WORK!!!!
  3. Get an Sata DVD Burner
  4. Bigger Power supply
  5. Different Graphics card.
  6. What is your budget??
  7. What are you going to be using the computer for??
Y a Different Gcard?
Nice
+ 1
Lol,
would you like me to do a build for you??? I can do you a good one :)
SURE! I Will Luv u.. and cherish u...
lol not rilly, but still, if u can, plz do XD Im new at buildin
Can u make it in the 14 to 16 hundred range plz? cause a monitor wouldnt kill, with the extra money...
