No second monitor with 9800gx2
socomm203
I just installed a 9800 gx2 with the newest drivers from nvidia.com. The problem that I am having is that when i go to change it so that there are 2 monitors there is only one displayed. There is no option to expand my desktop onto another monitor. I know that both of the monitors are working because I plugged them into the same dvi slot and they worked. Also when I attempt to go to the nVidia control panel I cannot see it because it goes off the screen like there is another monitor there. When i move the mouse over to the edge of the scree however I cannot go past it. Any ideas?
i don't think you can with the 9800gx2, i think if you look on the taskbar(thing with time) it should say sli enabled or something, you might be able to disable it that way, otherwise i know something like the radeon 3650 is a cheap alternative(has two dvi ports)
I wasnt able to disable it, but I just used my 8600gts that I had before to display on my 2nd monitor. The strange thing is when i go to set up the two monitors in windows it show that I can potentaly have 5 monitors. That could be because there is a HDMI on the gx2 as well. Wel the problem is solved though.
