Simple Network Issue
Cpetrie
Hello all,
In the process of trying to setup a basic 2 computer network over LAN I made a change to my computer that I do not like. When I start my computer it tries to connect to a network, but there isn't any, as I failed to set it up. It starts up differently than it used (sorry that's so vague), another more specific change is that when I press Ctrl-Alt-Delete it comes of with several options, one of which is "Task Manager." Unfortunately I made several changes based on several guides and I'm not sure how to return my computer to a "non-networked" state. Any help would be appreciated, thank you.
Look under your local area connection properties and make sure that client service for netware isn't installed. Not sure if thats the only setting you have to change or not.
Are you saying that is doing this before you see the windows logo on the screen? If so then its trying to boot to a network via the lan connection. You need to go into the bios and disable the "boot to lan" option
