Does my PC have a PCI 16X slot?
Asmflu
Hi, my first post here!
I am currently in need of getting my graphics card changed. My computer is a Dell Dimension 9150, atm i got a Nvidia GeForce 7300LE.
Now, i've set my eyes on a couple of seemingly good replacements, but they both require me to have a PCI x16 slot. I've looked around on the forum, but have not come across any description of how a slot like this looks, and i dont want to buy a new card before i'm entirely sure that i can use it.
So i took a picture of the inside of my computer, hopefully someone can tell me if i have what it requires to make the change.
Thanks for the quick reply.
The whole reason to why I am thinking of getting a new graphics card is because my screen looks like this:
Shortly after i see this screen I get a bluescreen.
I contacted Dell and they told me this was probably caused by my graphics card being broken. So therefore i can't download the wizard.
My PSU is also from dell and the model number is from what i found: N375P-00
It could just as easily be heat, or a psu issue:
...To be sure, please download PC wizard and install it, run it and go to FILE, SAVE AS and click OK. Then copy the text out of that file into this thread.
Cheers, also, look at you PSU and tell me what make and model number is on the sticker. Thanks.
