New Upgrades
Newegg stuff came today.
I'm probably going to end up buying a PSOne screen for that mod.
I plan on doing wire management tomorrow, and I'll probably pick up some splitters this weekend, so I can power all my fans, lol.
I also ordered that PSOne Screen earlier today.
Yeah, I installed it, its housing the green intake fan, I may cut the grill out, since the LED lights are shining through the grill on the Kama bay, and on the grill plates on the case.
I also have to remove some of the air filters, its blocking some of the light.
And thanks!
I need to find a good place to mount the LCD screen.
And thanks!
Ah right, I didn't see it behind the case face plates there.
How's about mounting it on the inside of your case, and have it on the window?
BTW, You know that you won't be able to use any second monitor with SLI Enabled?
http://www.overclock.net/nvidia/381100-sli-s-video.html
lol
Would soldering it onto the circuit board of the GPU work?
And why cant I run a second monitor with SLI on?
I mean its doable, I would only be using it at LAN parties, and when I do, I could disable SLI, show it off, and then turn it off when I'm going to game.
You're spying on me,!? :eek:
I don't think there's any way you can use two monitors with SLI enabled, unless you buy a cheap PCI card, I know you can run another monitor off that with SLI still enabled.
Lol, I googled the SLI and dual monitors, and that was one of the first posts.
Also, I plan on making the front more bright, by adding two blue 4'' and two green 4'' cathodes next to the front intake fans.
I am starting to realize that I'll be needed a lot of splitters..
I was going to add 2 more sets of cathodes in the front, and I couldn't get the 4'' cathodes to mount because then the drive bay covers wouldn't fit.
I went to Microcenter today, and bought the bendable SLI bridge, as well as 4 splitters, I'll work with them tomorrow.
And I've decided that I'm going to try and build an external case for the PSOne case, because it would be useless to mount it inside the case, and use it when SLI isn't enabled.
I took the grill off the Kama Bay, and it fits in now.
Ignore the wires, lol, I'm going to start working on cable management tomorrow, and throughout the week.
Got my LAN on Saturday! :D
