microphone jack on back of pc...how do i record?
fastforded
theres a microphone jack on back of pc...i want to hook up a mic and wondered how do i record a mp3 file i? :confused:
do i need special software to record, or can i use something in vista? any help appreciated! :)
Depending on the mic, you might have to get a mixer. For instance if you just have a regular desktop mic than a mixer is not needed but if you have a studio type mic then you will need a mixer and then you just plug the mixer into that audio port.
Yes you will need audio recording software in order to record audio (obviously)
Audacity is a free program with decent amount of options. I use Cool Edit Pro which is the predecessor of Adobe Audition and it's awesome. Lots of options.
